- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
It looks as if he was doing a 3 link setup using the trailer ball method, but decided on heims in the end.
I believe that is considered a 3 link setup as well since both the upper links connect atop the diff.
There are alot of desert style trucks that run leafs under the axle, and rely on good springs (like deavers) and a good shackle and shock setup to get alot of travel.
I havent seen anywhere that when you go SOA your center of gravity is raised a little more.
So lift does not = flex
But going SOA really gains some clearance for rocks on the already groudn clearanced challenged Explorer (especially the spring hanger)
So it really depends on what you use the truck for, trails and low range 4x4ing = SOA
High speed whoops, etc.....SUA
My BII was SUA stock and I can see why they made the Explorer SUA in order to improve the ride of the stock vehicle. A properly setup SOA will not effect the streetability much, in fact my truck is about 10 times better then stock and I am just getting started for the rear axle
I am going to do:
Deavers
Shackle reversal
extended shackle (possibly depending on ride height)
and some resevoir shocks through the floor with a cargo area cage (cant call it a bed cage in a BII
limit straps
I am going to do:
Deavers
Shackle reversal
limit straps
