oh no....has to be lim or valve covers.
I really am having re-occurring nightmares over this.
So sorry, I have absolutely no words of wisdom for you.
It would be really easy to see whats going on with the motor out of the truck, but who wants to live that?
I wish I had a second car (or that this was my second car) so I could do stuff like drop the trans or pull the engine!
I dunno about the LIM. Last time I used the Chilton's book and it gave the torque spec for the 4.0 OHV as 18 ft-lbs. No breakdown by year.
This time I used the Haynes book and it gave the torque spec for the 1996-1998 4.0 OHV as 12 ft-lbs (actually 144 in-lbs). There were different specs for other groups of model years, but the Haynes book didn't specific the lower intake. On the installation section for the lower intake it said "tighten to the number in this chapter's specs," and in the specs it just listed "Intake Manifold." (did not specify upper or lower)
I'm waiting for the car to cool, but it seems like most sources point to 12 ft-lbs as the proper LIM bolt torque spec. I want to check:
A. Did the valve cover bolts lose their torque? [UPDATE: The valve cover bolts lost about 1/4-1/2 turn of torque. I'm torquing the the Haynes spec--72-89 inch-lbs, so I went with 80 inch-lbs]
and
B. Did I lose more oil than I normally lose? For the past year of commuting, I've been "burning" (ie losing) about 1/3 quart of oil per 300 miles. I thought it was just normal for a 150k engine.
Could be that, say, 50% of my oil loss was due to a leaking LIM/valve covers. And 25% was due to normal oil consumption. And maybe 25% was due to another age-related leak or whatever. I've been noticing lots more oil residue in the air intake tube/upper intake manifold, as well as a mysterious oil buildup around the PCV valve grommet + on the brake booster vacuum line where it connects to the upper intake manifold. Lots more blow-by?
[UPDATE: The engine lost no more oil than "normal." I burned bout 1/4 quart in 300 miles. So maybe we're getting somewhere!]
The engine still pings on hills, so I wonder about that. Maybe my valve guides are worn out and that's why I'm burning oil/pinging? I had a valve job done when I replaced the head gasket at 120k mi/10 years ago.
Aside from the oil leaks and pinging, the engine gets great mileage (20 mpg highway/15 city) and still purrs like a kitten.
