Supercharged 02 Sport | Page 9 | Ford Explorer Forums
So how much did this run you all together thus far?
running total is about $2000 but remember I snagged this off of someone else on ebay. I still need to spend at least another $1000 for Maf, Injectors, and Dyno tune. plus if you count the Diable Maf.ia and new exhaust setup... an extra $200 (ish)
im putting on my wish list... hurst short throw shifter.
Please ignore my ignorance here cuss I know nothing about a 'short throw' shifter. I'm assuming this is for a manual trans?
yea its a 5speed tranny. the throw from gear to gear is reduced with the new shifter.
Kabukie - Just for my knowledge, what did you have to do with your PVC valve?
With the kit I purchased there is a ... nylon...? block that it mounts on just behind the throttle body and before the piping that runs into the back of the s/c. That and I had to extend the wires for the pcv valve. that was one of the easier parts to install.
can u post up a vid of the charger building up?
you lost me there. accelerating? building up boost? It only builds boost when under load. so I cant just sit there and rev it and build boost.
Sorry, just rev it. i want to hear that thing.
sounds pretty much the same as a n/a 4.0 with a slight whistle at first but thats the bypass opening up.
so what did you do with your setup before selling it? I skipped alot of the posts about maf's and didnt see anything new.
which maf, injectors, pump?
Joe probably won't look at this so I'll answer for him. He had 24# injectors, Stock MAF with a Diablosport Mafia on it and the stock pump.
