That is just plain wrong. Every meter is individually calibrated for its individual injectors. 5.0 mustangs are calibrated for 19# injectors, 93-95cobras for 24# injectors, lighting pickups for 42#s, and so forth. you stack a bigger maf made for different injectors on your motor and see what happens. The 88-93 5.0 mustang MAF will work on the 4.0OHV motors though since they both use 19# injectors.
I suggest you check this link:
http://www.diablosport.com/index.php?module=htmlpages&func=display&pid=4
and read about the MAF extender. I am suprised someone with a turbo doesn't know this information.
[edit]I can't even stop there. I just can't see how you could say something so wrong with the application you have. If what you said was true, then there would be like a total of 6 ford MAFs ever made, varying only by diameter. Instead there are literally hundreds of them, each made for its own individual application. If you're working on the peter principle (dazzle them with brilliance, baffle them with bullshit) then do it with something of your own and not someone elses engine. Before reading this, I would personally have taken some of your advice seeing as you had a custom remote turbo setup. Now, I wonder if you know the difference between a bowtie and a blue oval
