Superrunner lift is installed | Ford Explorer Forums
  • Thread starter Thread starter WAExplorer
  • Start date Start date
W
WAExplorer
I got the lift and my son and I put it in on 5/1. Started at 9 AM and finished a little after 10 PM. Superlift did not send the radius arm bushings and they sent the wrong rear shocks, still waiting for those things so I can align it. I did it where I work and used a lift and had torches and air tools. I only had one problem which is my own fault, I torqued the u-bolts with the rear axle hanging instead of torquing them with the truck's weight on the springs so I think I had a false torque value cause the next day I drove it and the rear drive shaft pulled a part. When I got it home and looked it over the axle had turned pinion down. Loosened the u-bolts and put everything back together, torqued the bolts with the weight on the springs this time, rechecked the next day after driving it to work and has been OK since.
