Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
Hey guys, just wanted to see if this problem I'm having is a common one and what exactly the cause might be:
If I get under the truck and look around, the oil pan/Diff/Starter area...it looks like I've got a significant amount of what I believe to be gear oil sprayed all over down there. The rear part of the oil pan has it on there, and the starter/area around it are coated in it. It's too sticky to be motor oil or trans fluid or something else...not sure what gear oil smells like but I think that's what it is.
Doesn't seem to be dripping fluid on the ground when the truck is parked.
What might be the cause of this? I just had the pinion seal changed out!?
