Timberwolf
- February 11, 2004
- Lewistown Pennsylvania
- '92 XLT
I have a 92 EX XLT 4-Door A4LD and the tranny is toast. After searching and reading and learning I've come to the conclusion that this particular transmission is near to worthless and anything I do is going to be costly and most likely the tranny will fail again. Cost is a major issue and all work I will do myself... hopefully! I'd like to remove the automatic and install a 5 speed manual. I've done some searching through this site and I see that its been done to various vehicles but I couldn't find one specifically detailing a '92. My concerns are cost of course as well as final appearance. Could someone be so kind as to provide a generalized breakdown of all parts I would need from say a donor vehicle to make this changeover? I'll list what parts I know so far and perhaps you could reply with added components needed.
Transmission.. Obviously.. But what do I need?
Front Drive shaft possibly?
Cluth and brake pedals and all associated linkage.
I've heard something about a slave cylinder..??
Computer from a same year make model vehicle with a manual transmission.
Wiring harness for said computer.. "How difficult will this be to remove and install?
Steering columm..??
Dash panel.. without the gear indicator?
I will most likely be buying a used transmission from a
local salvage yard and will figure on new clutch, pressure plate and throwout bearing..
Thank you in advance for all your kind input and advice.
Steering columm..??
