Bwana Bob
- February 2, 2002
- Morris Plains, NJ
- 92 XLT
For a long time I've been running with Tokico shocks and bigger sway bars in my '91. These were purchased as a kit from John Baker some years ago.
However, with Michelin LTX MS tires pumped to 32-35 psi, the ride is a little harsh. The suspension upgrade kit was originally tuned for the stock Firestone ATX tires (no doubt running only 26 psi, as originally recommended).
So, I decided to put the stock sway bars back on. The ride improved, but predictably, the handling
suffered (though its not bad with the Michelins and Tokico shocks).
Suppose I keep the stock front bar (23 mm dia) but put back the bigger rear bar (18 mm vs. stock 14 mm bar)? Would I get the best of both worlds or the worst? The stock front bar seems beefy enough, but the stock rear bar looks awfully skinny. I realize that its a tradeoff between ride, suspension articulation, and handling. I just don't want to do anything that will make it unstable.
Thanks gang.
Thanks gang.
