T-Case Mount | Ford Explorer Forums
T-Case Mount
Ryan1
White Bear Lake, MN
94 XLT
Does the T-Case have a mount like the tranny and motor have mounts?
The reason I ask is because, I was trying to pull out my Driveshaft I had all the bolts out but I couldnt get the end off attached to the T-Case. I realized that as I was beatin and shakin the hell out of the the T-case sure seemed to move around alot. Is that normal? or could I have a loose or broken mount somewhere. I also wonder because I have horrible vibration. It vibrates when Im driving with my foot on the accelerator. When I let off the gas the vib goes away. Its deffinantly comming from the rear driveline somewhere.
Ryan
No, the t-case bolts directly to the trany and they both share the trany crossmember mount. If you have a bad trany mount the whole thing can move around quite a bit but just make sure the 5 bolts from the t-case to the trany are tight and go from there. You might also be experiencing vibration from a bad u-joint or one that has been improperly installed.
