t-case problems | Ford Explorer Forums
t-case problems
parodox
ranger 2005
i recently changed the seal on my transfercase going into the rear driveshaft, when i put the nut holding the yoke on i left it about the same distance from the end of the shaft, but now i hear a sqeeking noise coming from it and the noise is irregular, could i have tightened the nut too much?
No I wouldn't think it is too tight, is the seal dry, did you use some grease for the seal to yoke.
I have heard new dry seals squeak before, even had to take a transmission back out just to grease the new front seal we just installed.
