Wanting to go lower gears and possible manual T-case, was going to try to adapt a 79 bronco case, but what other T-cases will swap in and be lower geared?? Some older Rangers or something? Thanks for the help
4 to 1 transfer case gearing in a package strong enough for big block power and full size trucks.... Or any other really abusive application you can come up with!
We've dramatically changed the Doubler™! The Gen2 Doubler™ is stronger, more compact and more versatile than ever. We've also developed a Doubler™ for Ford vehicles. See details below.
First, the Basics: The Doubler™ is an all gear, dual transfer case system uniquely suited to full size trucks or other heavy duty, high output/abusive applications because of the durability of its components (all massive helical gears and large input/output shafts). Basically, the Doubler™ consists of the gearbox section from an NP203 transfer case coupled to a complete 205 transfer case. This gives you an additional low range gear of 2:1 for an overall low gear of 4:1. Adding lower transfer case gearing gives you huge improvements in off road control and torque without affecting your highway gear ratios(4.10's with 37-38" tires works well). Adding a gearbox also allows you to run in your normal 2:1 reduction or in super low 4:1 reduction for best performance in any situation. We use a combination of bulletproof and easy to find factory parts with a minimum number of modified components to give you easy bolt together gearing options.
Pricing:
Part Number Application Price
GU4004 fits GM 203 to GM TH400 version 205 $740.00
GU4005 fits GM 203 with solid output yoke $800.00
DU4004 fits Dodge 203 to GM 400 version 205 $760.00
DU4005 fits Dodge 203 with solid output yoke $820.00
FU4001 fits Ford 203 to Ford married 205 $740.00
FU4002 fits Ford 203 with solid output yoke $800.00
Kit Components
The basic Doubler™ kit is intended for the "do it yourself" user and includes all the parts necessary to mate your 203 gearbox and your NP205 transfer case. These parts are a splined and heat treated adapter shaft to install in your 203 range box, a machined steel adapter housing, and the necessary gaskets, seals and hardware. We provide an oil fill and the breather port for the 203 range box.
Ford Transmissions (most types):
Conveniently for us, Ford used an identical round bolt pattern and 31 spline output shaft for all of the truck type transmission and transfer case combos. This means you can take your Ford NP203 and bolt it directly in place of most Ford transfer case without adapter and shaft changes. This also seems to carry into late model trannies also. If only GM used this system!
There are a couple of different output housings available for the back of the C6 that you should be aware of, info is a little sketchy but we know of at least 2 lengths, one is about 7" long and the other is about 5" long. The output shaft length must match the output housing length. Otherwise you can bolt a Ford NP203 gearbox directly in place of the Ford NP205, NP208, or even the newer aluminum cases.
