Tailgate/liftgate won't lock | Ford Explorer Forums - Serious Explorations
RobertFord
Amsterdam, Netherlands
1991 Ford Explorer XLT
Hi All,
Last night my '92 Explorer made the decision to no longer support me in locking my tailgate. This came after I had been out in about 10 degrees F. weather and opened it to remove some stuff. Upon closing it, it would no longer lock.
Before I was able to lock it with the pin through the tailgate window by hand, as locking it with keys seldom worked, but now this doesn't work either. As I had to park the car in a rather bad neighbourhood, I might have forced it a bit much, as it would seem I have bent something on the inside in my efforts to get it locked. (It now is)
In short: Tailgate won't lock, either by key or using the pin through the tailgate window (central locking doesn't work either) Unlocking goes fine. Perhaps cold weather is a factor.
Is anyone familiar with the problem of the tailgate not locking? I'll try and remove some panels this weekend to see if I can get it fixed, but I'm not too optimistic. Any help would greatly be appreciated.
I had same problem you need to lube the lock and the latches the latches a wd40 or white lithem and lock lube if they goes help your going to have remove the inside cover a locate the center lock mechaniz and lube
