4x4Hunter
- January 20, 2000
- Watertown, NY
- '91 XLT
Alright... I was going to start tearing down the electric motor on the transfer caes, but just prior to doing so, the motor suddenly started working correctly. I decided to leave it be as it was as long as things were good...however later I went to the mall and was testing to make sure it was still working and it cut out on me again. I'm starting to think that there isn't a problem with my motor as much as there might be a bad electrical connection at some point..ANYWAY... I went to Wal Mart to get some ATF fluid for the job that I was going to do, coming out of Wally Mart... I hit the button for the 4x4 and it worked again... again I went through the on/off routine...hitting th button multiple times and each time the mechanism acted as it was designed to do. Does anyone have any ideas? I did do the test on the module in the rear of the truck and the light blinked. What is the standard reaction for that light when there is NO problem with the mechanisms? I can really use some advice at this point... guys if you read this, please respond. As of right now, the mechanism is working as it is designed to do. I'm just worried that it wont keep doing that and I'll end up in a snow storm without my 4x4.
