The sending unit for the coolant temp is on the front of the upper intake and has one wire..
To start with, take the wire off the sending unit and ground it (connect a wire from it to the negative battery terminal)..
Do it with the motor off as it gets hot by that connector.. just have the key in the "on" position. If the temp gauge goes all the way hot then you know the wire to the gauge and the gauge are still working (at least not an open).
If it doesn't move you have an open in the wire (broken wire) or a bad gauge.. You can change just that part of the cluster.. the Water temp section (it will change the gauge right above it too)..
If it gauge moves by shorting the wire just buy a new sending unit and install it and that "should" take care of it.
This is assuming that its not moving, even when the motor is actually warming up. If its warming up, the upper radiator hose will get hot once the motor is up to temp.
~Mark
