Temp sensor, gauge problem... | Ford Explorer Forums - Serious Explorations
Dre
Chicago
2015 FPIU
help me figure this one out -
My coolant temp gauge does not move at all so I have replaced temp sensor - still, no movement so then I hooked up Auto Meter temp gauge to factory sensor and what did it get? it goes all the way up...
what could be wrong? looks that I can't hook-up auto meter gauge to factory temp sensor... what about factory gauge? does not move at all... gauge went bad? all other gauges work OK...
thanks,
new senser not working maybe
I need to hook-up my meter and see if the new sensor works... what is the correct resistance?
but - factory gauge doesn't move at all... auto meter goes all the way...
Maybe a short somehwere between the sensor and the guage. And isnt there two sensors?
I did that... gauge works - looks like I got me a bad sensor - AutoZone :shoot:
got to go to NAPA tomorrow to get another one.
Now question is why I can't hook-up AutoMeter gauge to factory sending unit?
Anyone install AutoMeter water temp gauge? I know it comes with sending unit but do you install that sending unit somewhere else to get the reading?
Did you check the sensor to make sure it is getting a good ground from the intake manifold, just to be sure?
yeah... maybe I used too much teflon tape...
:rolleyes:
cause I'm getting nothing when I check it with my ohmmeter, oh well...
