fissionbait
- April 26, 2009
- N America
- 97 ohv
So my trucks been missing quite a bit lately, especially when the engine is hot will miss at idle too. So wanted to check the wires but have no clue if I used the right settings on the ohm meter. I set the switch to 20K in the ohm range and plugged the two meter terminals up to "VΩ" and "com"(max 1000v). I tested the each sides of the 6 wires and got some mixed results:
wire 1 - 4.68
wire 2 - 4.52
wire 3 - 3.88
wire 4 - 9.52
wire 5 - 6.02
wire 6 - 6.71
Wire 3 was all over the place and skipped back and forth from 2V up to 16V and rested lower when the wire was still. Wire 4 was consistent but higher compared to 5 and 6(longer wires). So what do you think?
wire 1 - 4.68
wire 2 - 4.52
wire 3 - 3.88
wire 4 - 9.52
wire 5 - 6.02
wire 6 - 6.71
