ok there are a couple things that are missleading in tis thread,
A you cannot back flush a tranny, the pump will not run backwards
B flushes are a good thing AS LONG AS the PROPER fluid is used, in this case, it is Mercon V, also DO NOT LET ANY SHOP USE BULK OR GENERIC( THE STUFF THAT MEETS THE STANDARDS OF BOTH MERCON AND MERCON V) this is why peoples trannys fail
C the filter is a screen it doesnopt need to be changed every 12k thats a waste of money, 30k is fine , but your also only changeing 4-5 qts of fluid out of 12,
D from what i as a technician hae ben told the 5r55e trans( the ones with NO dipstick are serviced around 100k, thats what manufactures are shooting for, similar to the gold coolant and platinum plugs,
E he maintenance manual that comes with the Explorer says change transmission fluid at 30K intervals for 5 models of transmissions (AX4S(sable, taurus), AX4N(windstar), 4R70W9 (v8 explorer), expedition, 4R100( expedtion , nav,f150-450, 4F27E(focus). v6 explorers use the A4LD, 4R55, 5r55e,s,n, there for are not included, but most should bne servced at 30k, unless you do not have a dipstick.
F there is a recall to add an additive to the trans on the newer explorers, i think its 2002 and up, check with your dealer on this, or PM me your vin and i can check
all in all, flushes are worth the money when they are nessecary, if you have a dipstick pull it out if the fluid is black have it flushed. if you dont have it serviced when scheduled, also FLUSHING DOES NOT SOLVE TRANNY PROBLEMS, it usually makes them worse.
