Picture Update
Okay, got quite a bit done over this past weekend.
The first order of business was to make the doghouse skin all one piece. To do this I had to notch the inside of the front top corners.
After the notches were just right, I hammered the the top corners of the grille to match up with the sides.
Eventually I got the edges to match up and welded the seams and sprayed a little primer to keep the rust at bay.
I also welded the three tabs on either side of the grille.
The next step was to make the front quarter block-out plates.
Then the plate got welded and formed to fit the front quarter.
It's welded at the tabs and all the way down the edge so there's no gap.
I wasn't able to do the driver's side because I need to get a fender to cut down. (driver's side got bent up too badly in the wreck).
Next on the list was to sort out the electrics...
I was a bit overwhelmed with all the wires, but luckily my buddy was in town to help me out.
We dubbed the plug in the next picture an "electric circle jerk".
The carnage.
This rat's nest became the bane of our existence for the next 12 hours.
But we eventually won.
Now, there are no wires to plugs showing through the wheel openings (save for horn I think). Also, every wire is wrapped or loomed.
We started with this:
And ended with this:
hmm, apparently my camera decided to not save the finished wiring pictures. I'll edit this update later today and add them in.
The last thing I did tonight was secure the doghouse skin. To do this I chose to use carriage bolts. I started at the back since this is how the whole frame stays attached to the firewall. Considering I was ultimately drilling through a half inch of steel, these were the biggest PITA.
Eventually I got them all done and bolted in.
In the above picture you can see most of the reworked harness. The non-wrapped wires are only sitting there until I make the fenders. Then they'll be run to the turn signals.
And that's pretty much it for now.
Remaining To-Do:
- Make the fenders/install turn signals.
- Get another hood and left side fender.
- Cut said hood to size.
- Install left side block-out plate.
- Expanded steel behind grille.
- Hood Pins.
- Bumper.
- Paint.
I think that's it. Looks like I'm in the home stretch.
~Rev
