The X is jerking and the motor stalls when hot | Ford Explorer Forums
PROTEUS
El Salvador, America Central
Explorer 91 XL
When I drive a few miles the X runs good. But after the motor gets hot, the X begins to jerk, specially in a traffic jam, and after some seconds the motor stalls. This is specially when I have the A/C on. Another symptoms is when the X is jerking and jumping, the battery Gauge is oscillating between 8 and 12 volts aprox.
This is a really bad problem !! :(
The X stop of jerking when I turn off the A/C or I shift the trans to Neutral (when jerking the thrans was in D).
I have replaced the IAC, Fuel Filter, spark plugs and Injectors cleaned up.
Also, I got a 14 code on the test (PIP circuit Failure).
I have made a search and the problem seems to be a bad wiring or harness on the ICM and/or related components.
But I'm not sure, what else can it be ???
What components I have to test ?
Any comments will be helpful to me !!
Thanks for your replies.
Read my reply on the "High idle in park 1,500rpm and 900rpm stopped in drive, help!" thread.
Hope this helps.
check the compression
