Theft light blinking rapidly no crank | Ford Explorer Forums
Rogue473
Grants Pass Oregon
2002 explorer XLT 4,0 4x4
I have a 2002 Explorer XLT 4.0 I found that the fuse to the PCM was loose causing intermittent power to the PCM . I believe this caused PATS to go into theft mode I have fixed the fuse problem but now it still blinks rapidly and I can't get it to stop . What can I do now ?
Wait 90 seconds and then the pats system will begging to slow flash a code
You count the flashes and write down your code
Then google it
Could be an issue w the pats key or halo
