Thermostat and Temp. Sending Unit | Page 2 | Ford Explorer Forums
OK, I will try the thermostat first. I found one of the temp. sending units online (DY-681) and it is about 12.00 with a coupon. Does the Prestone kit come with radiator fluid, flush, and that input for the heater core? Ive seen the flush and radiator fluid seperate, but will look for the kit. Thanks guys! I should be performing this in about two weeks after I move into my house. Thanks again!
Originally posted by Triton46
I just went out to check out where the bolts are for the thermostat...holy cow! That bolt on the left as you're facing the front of the engine is tight, looks almost impossible to get at. I also found the 2 temperature sending units on the top of the engine. I will most likely replace these first and see if my temperature guage goes back to normal. Then if it doesn't, I will replace the thermostat while changing the fluid.
I went out to look at the temp senders and the one on the right appears to be partially unscrewed. I found the part number for one of them DY-681, does anyone know what the other one is?
Ric,
Yes I plan on using the Prestone kit, but you must first drain the radiator. Most of the fluid is in the block, and the Haynes manual mentions two block plugs to drain it but does not tell you where.
In order to drain the fluid completely, I would have to flush with fresh water over and over until all of the fluid in the block is water. Can anyone tell me where the block plugs are?
The beauty of the flush Kit is that you don't have to remove the plugs.
[Edited by Triton46 on 11-18-2000 at 02:04 PM]
overheating
Hi, I just bought a 91 ford explorer and it seems to overheat when i run the a/c. does anyone have any suggestions?
