archerobx
- April 27, 2006
- Pittsburgh Pa
- 1999 XLT
Have been having an antifreeze smell on the outside my car. I looked all over cant find any leaks. I am loosing alittle coolant. Felt the floor and firewall for a leak, ran the defrost for awhile and found nothing. No noises, gauges all are within normal limits, engine sounds fine.
Today I looked at the thermostat and there is a greenish crust around the seal, figure its dried antifreeze. Should I go and replace the thermostat and the housing seal or just the seal? Also does this sound like the solution to the problem I mentioned.
Than you
Than you
