Throttle Position Sensor & Error Code P0122 | Page 2 | Ford Explorer Forums
Hi ncranchero ,
Please send the TPS diagnostics to jerrypayne4444@hotmail.com I bought a new TPS and it sends me a P0122.
Thanks,
field
ncranchero or anyone,
Please send the TPS diagnostics either to the Yahoo mail account I posted when registering here or to jerrypayne4444@hotmail.com
Thank you,
field
This guy -
www.youtube.com/watch?v=FJobCD6y8fk
shows that the problem is seldom the sensor.
He is correct in my case. I got this same DTC before and after installing a new sensor. It is:
P0122 Throttle/Pedal PositionSensor/Switch "A" Circuit Low
So now I always have a roughly running engine unless I hold the pedal down to keep it above above 1100rpm.
Turning the sensor through it's range while it is out of the intake tube causes a change in the rpm, but not much. i.e. I have 5volts to ground where it should be, nd a change in rpm while turning the sensor and am mystified why operation isn't normal.
Any further ideas?
Still hopeing for that TPS test procedure
field
