Ticking Noise | Ford Explorer Forums
Ticking Noise
sjjones
Anchorage AK
1994 4X4 XL
94 Explorer 4X4 4 liter. Vehicle runs pretty good, but has a little rough idle compared to when it was new. Now has 110K.
I'm noticing a fairly light tick tick at idle. Wasn't so pronounced before. I also notice a throatier sound upon exceleration. At first I thought it was a small hole developing in the muffler, but am now associating the tick tick with perhaps a leaking manifold.
At one time I was thinking the rough idle may be coming from the lower manifold sucking air. I am now thinking I may have a leaking exhaust manifold. Could someone please tell me what type of test, or what to look for, to determine what the issue is. One thing is that I do want to get rid of the throaty sound. Mind you, most folks who hear what I call throaty think its normal - its just that I specifcially remember it was quieter before. Many thanks.
Don`t know about the throaty sound unless the intake system has a leak.
The ticking is most likely your hydraulic lifters, I have it too.
try changing your oil i know my friends old jeep was making all these wiers noises unitl he changed his oil
Thanks Folks.
I suspect an intake manifold leak or the exhaust manifold leak. Difficult for me to determine which. I am reluctant to try sraying the flamable stuff along the intake to see if I get a higher rpm - just seems dangerous spraying a flamable aresol on a running engine - but may try anyway :)
Oh, in response to the oil suggest - good suggestion - but I relegiously change oil and filter at 3K or less using Mobile 5-30 Syn. Obviously overkill, but I like doing it. Only have about 1K since last oil change. It ain't the oil :) BTW, I only use Mobile 1 because I live in Alaska and the truck starts a lot easier in the winter. I do get some minor leaks using synthetic, very minor, but the trade off for easier starts is worth it.
