Timing adjuster for 4.6l? | Ford Explorer Forums
psychotic
Olathe, KS
RIP: '02 V8 Limited 4WD
4.6L/5.4L FORD EFI VARI-TIME TIMING ADJUSTER
• Fits all 4.6L & 5.4L Ford auto and truck models
• Easy to install design
• Allows for easy timing adjustment for increased horsepower and torque
With its beautiful CNC-machinery anodized components and easy to install design. This timing adjuster kit for Ford auto and truck models is a great way to maximize your horsepower and torque potential and utilize aftermarket under drive pulleys.
This kit can be installed in less than 1 hour and adjusted in just minutes.
1640 4.6 V Vari-Time Timing Adjuster Unit
http://www.bbkperformance.com/products/new.shtml
will this work for the 4.6L explorer, what exactly does it do?
Also, do you guys think one of these throttle bodies work -
POWER-PLUS F-SERIES® Throttle Bodies for 1990-Current 4.6 & 5.4 2-V Ford Applications
• Available in 70mm and 75mm sizes
• Direct bolt-on installation - E.O.# D-215-18
• Adds 8-15 horsepower, crisper throttle response
• Standard on Roush Stage 3 Mustang
1700 - 70mm 4.6 2-V (Fits all 1996-newer 4.6 2-V applications, except for F-series truck)
1701 - 75mm 4.6 2-V (Fits all 1996-newer 4.6 2-V applications, except for F-series truck)
1703 - 75mm 4.6 2-V (Fits all 1990-95 4.6 2-V applications - also fits 1997-newer
4.6 and 5.4 F-series and Expedition models
http://www.bbkperformance.com/products/throttle-bodies.shtml
The timing adjuster SHOULD work on your X. Its the same setup as the stang, although dont hold me to it. It does just that- allows you to retard/advance the timing a few degrees.
