Timing chain PN for replacement | Page 2 | Ford Explorer Forums
Nice! cant wait to see the finished product! also hope you find that socket before it becomes a projectile... ask me how i know that lol
It more than likely fell and rolled under a cabinet or something. I took a magnet and went into every nook and crannie on the frame couldn't find it
I lost a 1/4” drive 13mm 6pt last month, removing the original rear shocks from the upper mounts. It somehow came off the drive and went flying up there. I looked around with a light, magnet, you name it. Gone.
These things eat tools...
LMAO
a few parts of my own should come later today... i plan to do the job over summer... the oil is coming in a week, but the filter isn't coming will the end of may??? i ordered from the same place, so oil is prioritized over the filter?? but anyways ill probably post some updates here over summer as i do it, although @Sandman92 would probably have finished his build by then...
If you're wanting a motorcraft filter most auto parts stores carry those.
ill call them but in the past this place doesn't pick up calls but they have low prices... ill try later today...
i called twice and they didnt pick up... ill just wait till mid may its not like i need it till beginning of June anyways...:dunno: :banghead:
Well I'm deciding to do the head gaskets and I have to say I'm not a huge fan of these torx ends on the head bolts. I got one side off, still one to go. What's the best way to clean aluminium?
for me i use rubbing alcohol, but since its unavailable, i use my denatured alcohol, i still have 2 gallons i never used lol
I got the motor in and back together. To my surprise there is still a knocking sound. How long does it usually take to purge the tensioners? I never heard this motor run so it could have internal damage I wasn't aware about.
About 1.5 sec on startup
Yeah I have something going on. It sounds like it's from the drivers side and sounds like a chain rattle. I'm guessing either low oil pressure or a bad tensioner.
Bad tensioner
try your old one if it's not damaged
Well I think it was the tensioner. I had another one, I read online to prime it in oil. Doing this made it rock hard and it pulled the threads in the head!... I have another motor I can rob a head off of. Is it possible to replace the head in the vehicle or is it e gine out again? It's the drivers side head...
Bad tensioner
So after composing myself after wanting to punch a hole through the door it seems like I'll be ok. It looks like using the tool the cam should keep time and I can pull this head with it in the truck. Looking at parts is just a head gasket and head bolts and a cam bolt.
if it's the primary tensioner, you can keep the engine in... that's my summer project, it will probably be a few weeks, but i'll probably make it a few months replacing junk i don't have to...
