Timing Chain Replacement Cost In a '99 | Ford Explorer Forums
Outshine2
Orange County, CA
99 Sport
Hey all... My '99 SOHC is making the dreaded rattle between 2.5 and 3K rpm's, so I took it to the Ford dealer hoping they could do something with the 01M01 issue (or similar)... Well, they are quoting that it is absolutely the same issue that was covered under 01M01 in the 97-98 SOHC's, but that my '99 is not covered. Said they used a different part in the 99's that eliminated this issue (obviously)... Anyways, they are asking over $1,200 for the job... I clarified and made sure this is not chain (there are 3, right?) that can only be done with the engine removed. Seems high to me, but what do I know :rolleyes:
What do you guys think?
I think you might be covered under 01M01. 01M01 ends 7 years or 100K miles for all SOHC Explorers built through 10/20/98 at the Louisville Plant and through 9/18/98 at the St. Louis Plant. The 7 years begins the date of delivery so find out that date and where yours was built. If it falls in those dates above you should be covered. Don't forget, most 99's were built in 98.
Here's a little extra info...
00M12
Owner Notification Program 00M12 - Certain 1997 through 2000 Explorer/Mountaineer and 2001 Explorer Sport/Sport-Trac Vehicles Equipped with 4.0L SOHC Engines - Camshaft Chain Tensioner and Lower Intake Manifold Gasket Additional Coverage
PROGRAM TERMS:
On the affected vehicles, this program extends the coverage for the 4.0L SOHC camshaft chain tensioner and lower intake manifold gasket to 6 years or 72,000 miles from the vehicle’s warranty start date, whichever occurs first. This coverage will automatically transfer to subsequent owners. If the vehicle already has more than 72,000 miles, this coverage will last until April 30, 2001.
AFFECTED VEHICLES
• Certain 1997 through 2000 Explorer and Mountaineer vehicles equipped with 4.0L SOHC engines built at the Louisville Assembly Plant and St. Louis Assembly Plants from Job #1, 1997 through April 7, 2000.
• Certain 2001 Explorer Sport and Sport-Trac vehicles equipped with 4.0L SOHC engines built at the Louisville Assembly Plant from Job #1 through April 7, 2000.
SERVICE ACTION
• Owners of affected vehicles are being notified that Ford Motor Company is providing additional coverage for the affected engine camshaft chain tensioner and lower intake manifold gaskets.
• If either the camshaft chain tensioner or lower intake manifold gasket should require replacement, dealers are instructed to install both of these upgraded parts at the same time, at no charge to the customer.
• The no charge coverage for this condition is available for 6 years or 72,000 miles from the vehicle’s warranty start date, whichever occurs first, and will automatically transfer to subsequent owners. If the vehicle already has more than 72,000 miles, this coverage will last until April 30, 2001.
01M01
All 1997 and 1998 model year Explorer and Mountaineer vehicles with 4.0L Single Overhead Cam (SOHC) engines built at the Louisville Assembly Plant from July 29, 1996 through October 20, 1998 and at the St. Louis Assembly Plant from May 29, 1996 through September 18, 1998.
On some of the affected vehicles, the front cam chain guide assembly may wear or break and cause excessive cam chain noise that does not go away after five minutes of engine operation.
SERVICE ACTION
If the cam chain guide assembly is worn or broken, install a new cam chain guide assembly. If it has broken and fragments have entered the engine oil pan, clean the block of all debris, replace the engine oil pick-up and filter assembly, and install new oil and filter.
Thanks much for the information. I know they immediately dismissed that ONP because I had a '99, not sure if they even checked the build date.
How is the best way for me to find the build date?
Should be on the sticker on your drivers door I think.
Sorry to bring up a old post, but im about to get this fixed and i've been reading about it. Does anyone know why in the world this doesnt this cover a 2001 4 door? Im not big on conspiracies, but I think its rather convienent that the most common model is excluded. Im past 72k miles but not 100k so i'd fit into that recall, except its not a sport or sport trac! GRR
