Brasilnut
- November 10, 2004
- Venezuela, South America
- '98 xlt
my 98 xlt SOHC 4.0 with about 60,000 is producing a irregular tick/clatter from the engine. It is hard to figure cause sometimes it does it cold, sometimes hot and sometimes not at all. It only does it on start up and sometimes goes away after just 5 seconds and other times only after 5 minutes. Maybe a lubrication issue? I've been told maybe timing chain/s but how can I know for sure? If so, what all do I have to replace, chains(I guess there are four total), tensioners, cassettes and what all gaskets will need replaced. Should I order the kit for the whole engine? For that matter what all should be replaced or serviced while I'm in there?
Thanks for any help or advice you all might have.
PS. I'm thinking of doing the work myself. Is this sane or should I not even try it? I've pulled and replaced engines/transmissions before and replaced the crank and main bearings in my j**p cherokee once too. Is this much harder?
