Hi!
Try a search for tire conversion chart, or something along those lines.
That will let you put in you metric tire size and see exactly what sized tires you have in inches, then you can compare to other tires whether they are metric or high flotation.
IIRC 235/75's are 29 inches and change high, by 8 inches and change wide. Maybe closer to 29 and a hlaf, by 8 and a half. Can't seem to remember exactly though.
That probably didn't answer you question directly, but it may lead you to find the answers.
You have a 15 inch rim, so in most cases, at least the cases that you'd need to know about, the last number of any tire will be the rim size, so always make sure that is 15.
example
235/75 R15
31X10.50 R15
I believe, and I could be wrong, but I believe that after 235/75 R15 there isn't much in the way of metric tires for a 15 inch rim. It goes to 30X9.5, 31X10.5, etc, etc.
