Tire Rotation TPMS | Page 2 | Ford Explorer Forums
Tire Rotation TPMS
Do you use the TPMS from your vehicle computer to set your tire pressure? Your owners manual SPECIFICALLY says NOT to. Your owners manual will tell you to check your tire pressure with a gauge.
No vehicle with TPMS will "automatically" re-calibrate, it must be done manually. On my 2011 GM I could simply put it in TPMS mode and lower the tire pressure starting from the LF, wait for the honk and work clockwise. On my 2018 Ford I have to use a simple tool. Same horn honks, same clockwise direction. it's probably easier with an OBD tool but I don't need one at this time.
TPMS is tire specific, your car is not smart enough to reset itself. The reason the system does not trigger is your tires are set the same front and rear in the computer.
Seems to work fine on my 16 fpiu
