tire sensors | Ford Explorer Forums
tire sensors
jdzcn0
wahington mo
2006 xlt
I just bought a used 2006 explorer and the passenger rear wheel was changed with another wheel and tire off of a different explorer. The michelin tires say 44 psi max pressure. the door says 35 lb. the sensor light came on . can you not use the pressure off of the tires 44 lbs will that set off the sensor or has switching the tire and wheel off of another explorer caused the light to come on
