Tire Size | Ford Explorer Forums - Serious Explorations
Tire Size
A lot of them came from the factory with 255/70R16 tires, so you can definitely fit 255/75R15 (or 255/70R15) tires on there, with 15 inch rims.
31x10.50R15 and 30x9.50R15 LT tires fit as well.
i have i similar question i've got an 03 ex with 235-70-16 will 245-75-16 fit rite? will they rub or cause any damage?
If it came stock with 235/70R16's, going up to a 245/75R16 isn't much of an increase.
It's possible they might rub at full steering lock, but usually there's more than enough clearance to run slightly larger tires with no rub at all.
I'd say they'd be an ideal size if you wanted larger tires without overdoing it.
ok cool thank you for your info.
Thank you so the the 31's wont rub on a full steer
