in michigan i mounted Michelin LTX AT2's. . .245/75-17's.
Great in the snow, dirt, rain, haven't been in mud often. Good road manners, they have some noise with the window down. Primary reason why i bought these is the last set i owned on the heep lasted about 70-80k, 8-9yrs old and still had 4/32's left. I had to replace them due to worn ball joints cupping one, plus two bead leaks due to rim corrosion. Longest tires i've ever owned and there have been a few sets. . .
Another suggestion since i have the AWD setup, i got 5 tires mounted for $1k. With AWD they say you should rotate every 5k miles, and if you lose a tire you should replace all 4 or you could burn up the viscous clutch. With 5 tires in the rotation, if i lose one say at half life, i can switch over to a 4 tire rotation and not buy the 4 new ones.
