Tires, will they work? | Ford Explorer Forums
robmurt04
Pennsylvania
'94 4WD
http://philadelphia.craigslist.org/pts/436405889.html
"Set of 5 Dunlop Radial Mud Rover Tires 33x12.5, Mickey Thompson Classic II Alloy Wheels 15x8, PLUS a (TPMS) Tire Pressure Monitoring Systems.
The TPMS valve stems are already installed, all you have to do is wire up the monitor, takes 2 min. This set up is only 7-8 months old, still like new. They came off my Jeep Wrangler, 5 bolt pattern"
Will they work on my 1994 EX?
they should bolt on fine, but a stock 91-94 isnt going to fit a 33x12.5x15 tire without a lift
got the lift, just need tires. figured this will be cheaper. thank you
see if you can get a measurement on the centerbore of the rim, i think thye will work on your truck, but sometimes they dont as the explorer has a fat center bore to clear the hubs....
