TOE-CAMBER-CASTER -angles | Ford Explorer Forums
Repo
Helsinki
'91 XLT
I have a '91 xlt and the left front tire is pretty worn out on the outer rim. I suspect that the toe -angle is not correctly aligned at the moment. I'm going to a local shop where they have all the equipment&skills for this kind of job. But the problem is that I don't have the measurements for the adjustment. They might've been in the owners manual but for some reason my xlt didn't have one when I bought it 2nd hand.
So if someone have these measurements (I don't know if they are in inches or degrees or whatever but the people in the shop do), would you kindly email to me.
thanks,
Risto Eskolin
Helsinki,Finland
reskolin@yahoo.com
front wheel alignment spec in degrees
camber -.74 to 1.25
caster 2.5 to 6.0 (4X4)
caster 4.0 to 6.0 (4X2)
Maxiumun side to side diffrences
camber 1.0
caster (LH minus RH) =0.7 to -1.3
toe (inches)
-0.13 to 0.13
