///Manuel
- December 12, 2002
- Denver, CO
- 92 XLT
1. Are sealed power rocker arm decent?
2. Also, I like that metal felpro lower intake gasket, would I simply need a bead of rtv on the middle part since there wont be any material between the intake and the block.
3. Ford head gasket kit is $223 as opposed to $85 Ford head gaskets + $68 felpro valve covers + lower int, I'd probably go that latter route.
4. Anything else I am missing?
Parts:
head x2 kingcyl $500 (93tm's fully assembled)
push rods x12 smith brothers $100 (should have gone with rock auto sealed power?)
injector rockauto $67.79 (missing cap on one, I've changed all of them a couple of years ago)
pulley x2 rockauto $30
1 long exhaust bolt w701868s300 $15
1 short exhaust bolt n806171s2 $7
rocker arm x12 rockauto $158.28 or ford 6564 $396(!)
rocker arm roll pin no longer made by ford (can find at a parts store?)
exhaust manifold gaskets rockauto $5
low. int. manf. gasket rockauto $26.79 (incl. upper)
valve covers rockauto $23.79 (incl. upper)
OR
valve covers
+ low. manf. gasket rockauto (FelPro MS98005T) $67.99 (metal lower, incl. upper)
head gasket x2 ford 6051 $85.84
head gasket kit ford 6079 $223.71 (head, valve cover, up.+ low. int. man.+ valve seals)
head bolts ford 6516 $4.74 x16 = $81.61 w/ tax or rockauto $57
alternator ford reman 10V346 (GLV 8048 RM) $147.70
or ford new 10346 (GL-308-RM) $224.33
oil
coolant
pcv valve (can change later)
Parts:
OR
valve covers
oil
coolant
