pugsy
- October 10, 2005
- Toronto, ON
- '92 XLT 4x4 (4 door)
So I was driving yesterday at a cruising speed of around 85 Km/h, tranny kicked into OD as per normal. Then I slowed down a bit and I noticed my tach was down at 1K RPM, I stepped on the gas to try to kick it out of OD, but it wouldn't. I shifted into D, then into 2, torqure converter was still locked....was like I was driving a manual transmission! So I put into neutral and coasted to the side of the road. Turned off the engine, and then restarted to see if it would clear any electronic issues. I put it into reverse and it stalled out (was still locked). So I started it again and put it into drive, and it was fine, took off, gears changed normal as before and still kicked into OD at the proper time, then torque converter would unlock when I slow down. And it's been fine since!!
Questions:
- what would cause this to happen? Is my tranny telling me it's time to sell this beast? haha
- if it happens again, what can I do to correct it....ie, if I'm on the highway and crusing in OD, and I can't get into a lower gear when I need it - what should I do?
Questions:
