Keach
- January 31, 2000
- San Antonio, TX
- 98 xlt 4x4
Hello Folks, I am trying to adjust my torsion bars and have some questions. My adjustment bolts are off with the drivers side being fully inset and the passengers only half way inset. I tried a longer bolt in the drivers side, however did not get anymore lift. I then tried removing the bar and turning it 1/6th of a turn. When I did this my removal tool couldn't push the adjuster back in enough to insert the metal brace that the adjuster bolt screws into. I did this with the drivers front jacked up off the ground. If I lower the tire back down, will this eliminate enough tension to allow me to make the 1/6th turn? Am I doing something wrong? I've tried a search and haven't been able to answer my questions. All you help is greatly appreciated.
Keach
Keach
