totally lost | Ford Explorer Forums
totally lost
miranda
2004 ford explorer XLT
Hello, I'm Miranda. We have a 2004 ford explorer that is our baby. Currently trying to put in a new radio head unit in it. But desperately needing the wire diagram for the exploerer that also give description of what each wire is and where it should be reattached. The harness that came on the stock stereo has been cut off already. If anyone can help I would be extremely appreciative! Also I hope this is where im supposed to post this. If not I apologize!
Thanks,
Miranda:)
Also to go with my last post its a jenson vt9215bm stereo we are putting in if that matters. Thanks!
I would go to a junk yard, cut the harness from the same model you have,
and put everything back to original spec. Then order an aftermarket pigtail
(usually available @ walmart) that adapts everything from original to your jensen.
If you ever have to change head units again, it will be easy.
