towing a explorer | Ford Explorer Forums
towing a explorer
jsaid
urbana
98 xlt
Hi everyone,
is legal or not drive a explorer pulling other explorer with a tow bar ?
thanks
Umm, depending on what kind of Explorer is being towed, you're going to destroy the thing. Explorers, at least 2nd/3rd gen ones, have to be towed on a flatbed or their drivelines will get torn apart.
U Can Tow it with No Issues, As Long as the Drive Shaft is Pulled or U Put the Drive Wheels on a Dolly and if U have a AWD or 4WD Then U need to Flat Bed it..
If I read it correct, you want to tow an explorer with an explorer (your 98?).
Legal... Yea
Smart... NO.
The tow vehicle will be pushed around by the towed one.
I want to transport a not runing 98 eddie bauer . I want to save money in transport. My other 98 was totaled in an accident .
Legal... Yea
Smart... NO.
Actually, it may not be "legal" either.... Depends on which particular model is towing which particular model. A 4300 lb '98 Sport towing a 4800 lb '98 4-door wouldn't be legal as it's over the max towing weight and over the GCWR. The other way around, it may be OK, depending on whether the 4-door is a 4.0 or 4.6/5.0. Sport-towing-sport may be OK too. Again, it just depends on which model is pulling what.
In any case, the tow vehicle will likely be dangerously near it's limits. Adding a trailer to the mix just adds another 1500-2000 lbs. Not a great idea.
Oh, and you can flat-tow a 4x4 or sport. If it's an automatic, the engine must be running and in neutral, or it must be equipped with a neutral tow kit to tow with the engine off. Leaving the engine running keeps the bearings in the output shaft of the transmission lubed. If it's a manual tranny, you can flat-tow it with no problem as the gearing is splash-lubed.
-Joe
