MARALYN
- June 22, 2009
- SUNSHINE COAST QUEENSLAND, AUSTRALIA.
- 97 LIMITED
Hi everyone, this is my first post.
I have a 97 4l sohc auto ltd.
Decided to change oil in the diff's, removed the rear diff housing access plate to drain oil.
When the oil was empty i wiped the inside of the housing with clean rags and noticed small pieces of metal on the rags, on further inspection i could see the two gears [app 3" in diameter that are above and below where the axled end in the diff] were chipped but no teeth broken off.
I looked at every gear that i could and did not see any other damaged teeth.
Does any body know what could have caused this and what i should do.
The diff was working fine with no noise or problems.
I would have posted some pictures but don't know how.
Thanks in advance for any help with this problem, maralyn
