John4me05
- April 7, 2010
- Covington Va
- 94 xlt
Hello all. I have a 94 Exp 4.0 4x4 with 92K on the clock. It has a tranny fluid leak but i keep a check on it and keep it filled. Now to my issue. At times even after filling it with fluid it will free rev like being in neutral and i have to rev it once or twice before it will go. After it works fine. It could be the next day or a couple days later before it happens again. Any ideas. Could it be the touque converter. If so is there any way to play with the stall speed when i buy a new one to get a little more low end grunt.
Also seperate issue. When under load pulling a hill i get a rattle from what i assume is the valves. It occurs around 2300 rpm. Should the valves be adjusted. Are they adjustable?
