jaredk
- June 7, 2004
- Vt
- 2000 Explorer Sport
So I figured i'd share this. I (for the first time ever) decided to change the tranny fluid/filter. Used the good ol' Haynes book which either failed to mention the front driveshaft, cat converters, tranny and frame get in the way of removing the pan or I just couldn't figure out how to get the pan off. I ended up unbolting the front drive shaft and raising it and getting the pan out that way. Of course after fooling around with the thing for about a half hour first. Then it was a blast getting the gasket to stay on with so little space to work the pan around.
BTW... I probably smeared a little grease I used for the gasket inside the pan while I was trying to put it back on. That's not really a problem, is it?
So... I really like doin this stuff and it saves tons of money, but please tell me it gets easier over time. I only recently got into doing stuff to my truck myself.
Next up, transfer case fluid... if I don't break the truck first!
