Tranny Fluid Leak wayyyy up front | Ford Explorer Forums
01eddie
Grand Forks, North Dakota
2001 Eddie Bauer 5.0 V8
Hey everyone,
I've been leaking for quite awhile and when I checked it last night I was 2 Qt. Low. The leak is way up by the front bumper. Am I right to assume that there is a tranny oil cooler up by the radiator? otherwise it doesn't make sense. must be a fitting or something...... the truck is an '01 explorer with the 302. (5.0L to everyone under 50)
Thanks!
Brian
Yeah check das cooler.
I'd check out the rubber lines on the aux cooler in front of the radiator first, then crawl under and look at the metal line going into the radiator.
