tranny flush poll | Ford Explorer Forums
tranny flush poll
If you were having a shifting or shudder problem and you flushed your tranny fluid di
  • 1. fix the problem?
    Votes: 1 33.3%
  • 2. Make it worse?
    Votes: 0 0.0%
  • 3. Had no affect?
    Votes: 2 66.7%
  • Total voters
    3
checkedout
Falling Waters WV
1996 Explorer XLT
If you were having a shifting or shudder problem and you flushed your tranny fluid did it
1. fix the problem?
2. Make it worse?
3. Had no affect?
Is your 96 a V8? I ask because you mentioned shudder, and if you have the V8 that means you have the 4R70W trans, which is known to shudder.
There is a TSB updating all 4R70W trannys to Mercon V fluid, which helps eliminate shudder.
no. I have the v6 auto
I flush and use synthetic ATF as a preventitive measure; never had any tranny problems.
I would just change the filter. You are changing about 1/3 of the fluid doing that and its much cheaper. The filter change is something you would/should do if you get a flush anyway. In my experiance if a filter change doesnt help a flush isnt gonna help either.
While you have the pan off install a drain plug and it will make the next change much eaiser or at least less messy.
On a veh. that age you should be doing a filter change one a year. Cheap tranny insurance....
I flushed the old fluid and the shudder is gone. It's only been a couple days though.
