Techmonster
- January 23, 2003
- St. Cloud, MN
- 94 Limited
I'm having problems getting a solid answer to this from people at work...
When you get your tranny serviced should you get the tranny fluid flushed out(all 16 qts or whatever and not change the filter) or drop the pan and change the filter and only add the 4-6 quarts then and leave the other 10 or so quarts in there.
I service my tranny every 15,000 or so just to keep it running fine and some people have told me to only flush your system if it is routine maintance, and drop the pan and put a new filter put it if your tranny is slipping or having troubles.
What do you guys do...or should you maybe rotate every 15,000(change pan filter one time and then flush next time)
Thanks for the help
Thanks for the help
