Nocturnall
- March 28, 2006
- Tempe, AZ
- 1997 Sport
So it's not a typical thread about a transmission cooler.
I have recently stumbled upon a potential reason why I've been seeing such high temps in my trans fluid 200 - 280. I have a large 12 1/2 x 17 x 3/4 in trans cooler http://www.transmissionpartsusa.com/Transmission_cooler_p/600-000013105.htm
installed as well as a remote filter http://www.transmissionpartsusa.com/15709_Remote_single_filter_mount_p/600-000015709.htm
I had them installed so the fluid came from the transmission into the filter housing, then into the cooler, then into the radiator with a temp sensor located in the filter housing. Recently I decided to move my cooler higher up so it wasn't so close to the ground. When I moved it I had to rerun the cooler lines so this time around I went from the transmission, into the cooler, then into the filter housing, then into the radiator because I had a suspicion that the filter was slowing the flow down and not allowing fluid to flow enough to cool. So now the fluid will be slowed and forced to sit in the cooler if in fact that is happen.
Upon driving to work today under conditions that normally would have pushed my trans temps to 160+ degrees easily it stayed around 110 and didn't climb. Even sitting idled usually the temps would increase and they just stayed put today. More testing as well as pictures to come.
