thebrakeman
- February 11, 2009
- Canton, Michigan
- 2006 Mercury Mountaineer
Short question: Do I need to have my transmission serviced based on my use (see below). If so, pan drop with filter change, or flush?
Vehicle history:
We purchased our '06 Mounty in 2010 with nearly 70,000 miles on it, and it's been a pretty good vehicle for us. The previous owner had all of the fluids changed (rear, center, front, and trans) at around 60,000 miles, as well as the spark plugs (smart dude!). The trans service was a pan drop. They had used the vehicle for occasionally towing a 1-horse trailer.
We tow a travel trailer (loaded weight around 5200 lbs) 2-3 times per year to a local campground (within 1 hour). In 2010, we took at 1900 miles tour around Michigan's Upper Peninsula, and we've had 1 trip another year perhaps 2-3 hours away. Point being, most years, the towing duty is fairly light.
I have not touched the transmission since we purchased, and the truck is nearing 120,000 miles. I'm wondering if this might be the time to have the pad dropped again, but not sure if mine would be considered "severe duty". If not considered severe, maintenance schedules says don't touch it. Can some places inspect the fluid (from the little fill port below), to check the quality? There is no dipstick. If the fluid looks/smells good, maybe I should leave it alone?
Vehicle history:
