Zachsharp1989
- June 6, 2015
- 2007 Ford explorer
Ok, so after removing the trans plug i had let out about three quarts maybe four of my trans fluid. I think it was strange because that's all that had came out. I read that the system capacity was between nine and twelve.my question is would their still be most of the fluid in the trans/cooling system? My plan is to add the amount that was lost and I'm not very educated on the sealed trans that is on my truck.second question being what should i be weary of when adding? From what I've researched i will need to pump the trans fluid in,roughly four quarts then start the truck with fluid nipple still in place then proceed to warm up to operating temp at that point wait until steady stream of fluid turns to a drip that would be topped off then replace torqx bolt. Sound right? I'll be doing this today so input associated.also i read allot of back and forth on the use of mercon sp and Ford changing the standard recommended atf from mercon sp to lv as the sp it's supposed to be discontinued. Anyways, Thanks!
Zach
Zach
