Trans Leak | Ford Explorer Forums
Trans Leak
Nuggethead 420
Milwaukee, wi
91 Eddie Bauer
Can a TC leak or loose fluid?
91 A4ld trans Original TC.
I have fluid leaking out the bottom of the bell housing.
yes they can leak. I work at a transmission shop. You more than likely have a bad front seal. The transmission will have to be pulled to fix it if its a front seal.
Update: Tranny came out without a hitch and changes the input shaft seal, intermediate servo, and rear main on the block. It all went back together and runs like a champ. No Leaks thank God!!!
